Tool/Bit marks/ridges
I’ve tried to search for a solution but have come up empty. Anytime I do a 3D project I get tool marks that are difficult if not impossible to sand down properly. I have utilized a 40% step over in order to try to minimize the marks with little success. I have seen some projects that look almost smooth without sanding and when I do a regular pocket carve, it is 95% smooth.
To recap, I have a 40% step over while utilizing a 1/8 in round nose bit.
Any suggestions on how to minimize these ridges?
Have you tried going with a smaller step over? Have any pictures of the result with the 40% step?
40 is way too much. 40% is good for a roughing pass to hog out material fast.
For no-sanding finish I usually go 5% Up until 10% would be good finish without too much manual cleanup.
Obviously better finish means much longer cutting time… Going from 40 to 5% will be 8x cutting time. It’s a tradeoff you need to decide on.
The smaller step, you could increase your feed to compensate for some of the added time.
http://cncprogramming.martinchick.com/ball_mill_finish.html
Look up “ball end mill scallop” for some good explanations. Here’s a no frills calculator:
http://www.custompartnet.com/calculator/step-over-distance
I was having the same problem on the project below. 40% was too big I switched it to 5% and a 1/4” ball endmill. You might also try a 1/4” ball end mill.
1E1F06B8-F0BE-4288-8BFF-39E3B48727E8
@Zach_Kaplan, is that Corian? Do you do anything with the milled surface to “finish” it?
Yes that was Corian.
I did one where I sanded it and one where I didn’t. They also make some solvent for Corian that congeals the surface a bit. It’s an industrial chemical so I didn’t try it.
