Hi there, i was just wondering if anyone has made any of these? They are cutouts for wrenches and screwdrivers and things. How would i go about measuring each wrench and screwdriver to fit nicely in either wood or foam. Thanks!
Some examples.
Some examples.
Been doing some research on one of these drawing tablets, tracing would be awesome assuming it would work well with Inkscape. Anybody have experience with a device like this? Page is unavailable
cheapest option… take a solid black marker and trace them. scan the trace and use illustrator or inkscape (if it has this feature) to do a image trace and make paths using the marker trace. this should also give you a good offset since you were tracing the outside of the tools. Do a test and see if it works.
