Today I had a go at tramming my X-Carve, using the tool based on CNCNutz video.
Because the clearance is so low on my (Standard) X-Carve I had to trim a bit off the top of the stick, which accounts for the ducktail above the screw. I used an old 1/4" drill bit and unlike the one Peter made I just used a small nail for the side that touches the wasteboard.
I tried to adjust the front/back error by loosening off three of the bolts either side of the X-axis beam, although there was no obvious movement unless I used a pipe wrench to get some twist on. Eventually I managed to get it pretty nice (temporarily) but when retightening it all went to hell again. After several attempts one of the screws was not tightening properly any more, so I had to give up on that method. My screws are the torx head thread cutters that came with the original machine, I will try using an ordinary M5 with Locktite and hope the remaining three screws will hold things together for a few more years.
After that I decided to go with the aluminium can strips stuffed down behind the Z rail. This was a real pain as well, to loosen the bolts at the top I had to remove the plate that holds the z stepper motor, which meant It was pretty much impossible to check the adjustments without replacing the plate, one screw, at least.
Anyway, I after probably a couple of hours of jiggling and going back and forward I gave up on perfection and settled for about 2mm difference between the front and back measurement.
After I put everything back together I ran another skim pass using Easel, same as last time except only 0.4 mm deep, to see if the washboard effect was gone. It wasn’t, but much less than last time, and I think it may have been some of the leftovers of the first skim due to the very shallow cut.
Now for today’s questions.
- Is Locktite and a normal bolt the best way to fix my slightly loose screw?
- Should I change the other screws as well, or save it to the next time I try any adjustments?
- Easel recommended speed was 1016 mm/min (40 in), with the 18 mm bit. I didn’t speed it up due to not wanting to risk my wasteboard. However, later when I was trying out flattening some cedar with the same bit, I had to run it at 1800 mm/min to stop the bit burning the wood. What sort of feedrate are others using for these shallow passes?
- The machine kept pausing in the middle of the X axis movements. I didn’t notice this on the Y axis at all. I don’t think it was missing steps because once finished the bit was at the same home position, as far the human eye could tell. What might this be? I can add a video if that helps, but basically it just stopped for a fraction of a second at random points during the straight moves, NOT at the corners.
Any advice or comments welcome!
