Triple block(xyz 0 finder)
I am wondering if you are working on a app for the triple edge finder? It would really make 2 stage carving more precise. And it would also be very helpful when something goes wrong so that can restart. I tried several times to use last xy position for zero and when starts carve it goes totally opposite direction and makes some not so good sounds.
I watched his and I am interested, but right now I only have easel. Can it work with easel?
You can set it with ugs and then open easel and then skip homing in easel
Thanks I’m getting pretty good at easel now I will try out some new things out like ugs, and maybe fusion 360 unless there is so.ething out there that is better and or easier to lern.
