Thanks, Charlie for the reply. It’s all making sense to me. I’ll see if I can put it into practice.
Thanks, John. You and char have been very helpful. As I mentioned I have updated to the version you linked to, though I haven’t had a chance yet to try it out other than setting up Charlie’s Triquetra. I’ll be in touch after I have a chance to give it a go.
My question is where do i find the gcode. I looked in the tool box but could not find it there. Give me a hint.
On the Main menu select the option that fits you software. Easel, Carbide Motion, Mach3, Generic GRBLE etc.
Generic GRBLE will work with UGS, and PicSender as well as others.
I’ve chosen generic GRBL and it seems to be working. Not sure about the M02 checkmark though. I’m using an X Controller with an X Carve and Picsender.
I doubt you will need the M02. I always suggest leaving it unchecked to start out and then only check it if you get a end of file error.
Thanks again Charley. For everything
