Here it goes. My X is behaving odd. I calibrated the steps per mm and got it spot on going from 0 to 200 and back to 0. Working great. Then from 0 I say go to 100 and it goes to 99.5, then on to 200 and its on, then 300 and it goes to 300.5, on to 400 and it goes to 401, then 500 and its about 501.5.
I have swapped motors and it has continued. I swapped where the cables plug into the. Shield from X to y and even plugged into y axis and using those controls it persists.
as a note I’m working with the inventables team to try and figure this out but thought I would post on here.
I checked a couple more times and it still the same issue. Now coming back after the 100 increments up to 500 and it being at 501.5 on each 100mm increment its ~1mm off on the + side at of each Mark. But arrives back to 0 perfectly
You should do the calibration using the largest movement for your machine. Once you get that spot on then check the shorter distances and see if you have better results.
Since you have two motors in parallel on the y axis each motor is getting half the current that the X axis motor gets if the current limit potentiometers for those axes are set to the same value.
Try putting the X motor on the Z driver and the Z motor on the X driver and see if the Z motor then gets hotter than the X motor.
What is your drag chain situation? How many and what size cables are in the drag chain? What size motors do you have? I was losing steps because I added some cables to my setup and the motor couldn’t fight the bend resistance of all the cables.
I had reduced the potentiometer on the y axis during the switch. It not only gets hot while moving it gets hot while holding. I can try switching to z axis today.
All cables in the tray are the standard ones from inventables. 2 shielded and 2 limit switches.
I though it was losing steps, but during a cut it follows the same path every time. And during the calibration I noted about it would also be gaining steps.
Are your Y axis V rail/ V wheels clean? The only thing I can think of that’d cause intermittent mm / step is location specific mechanical interference. But even that wouldn’t make sense for gaining steps. What in the world.
You wouldn’t happen to own an oscilloscope, would you? I’d be interested in seeing the stepping pattern of the three wires to the X axis motor. Did you say you were using shielded stepper motor cable?
Oh. Well then I mostly take back my suggestion about the belt, that sounds like a potentiometer setting issue. It definitely shouldn’t be getting very hot doing nothing. Try bringing that down a little and seeing if it cools off.
