The software is recognizing the x-controller after emergency stop. Help?
Have you reset the E-Stop button all the way?
{:0)
Brandon Parker
I had that exact problem which was inside the e-stop switch it can get stuck in the off position. If you pop the bottom off the switch you can mechanically see what’s going on.
