as the title indicates, im trying to do my semi-regular calibration on my machine.
the problem is, when i use the machine inspector/advanced to find my current values, the pop-up is off the botom of the screen, so that i cant see or scroll down thru stepper values/grbl settings.is this a screen resolution thing?
also, im having a hard time remembering which $'s are for x,y,z steppers
BrianSaban
Oct '17
Ok just checking, do you happen to have the grbl settings for the original 23‘s on the 1000
LarryM
Oct '17
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.947 (z, step/mm)
Oh, and I think I was supposed to mention Blue Locktite somewhere in the last post.
I was having the very same problem last night, got tired of it so I just grabbed another computer that I had and replaced the one that I was using with the xcarve.
I just grabbed the info above from this topic; (best upgrade ever). I hope that helps, and check out that topic, it helps alot with the settings!
Sounds like some sort of issue with the website or your browser.
Did you check it in another browser?
Did you try screen zoom (ctrl+shift+plus / ctrl+shift+minus)?
Did you try rebooting your computer?
