Trying to cut a complex path with a T-Slot cutter, please help
Can’t tell if the upper edge will cut on the way up though, perhaps.
I suspect all things considered that this will fail dramatically so I will film it and post once attempted :slight_smile:
Then try Strooom’s sensible idea of 2 parts with simple pockets :wink:
I create the part as two vectors. use a drill bit for the round part, then tell it you are using an end mill, but use the key hole bit instead. Then.
