So after getting the CNC4Newbie 7" z-axis up and running I went to check square, and the right-left it was perfectly square and It was massively off front-back (i.e. in the Y-axis), Initially I checked it with my machinist square, but for the photo I used my carpenter’s square as the blue anodization makes it easier to see. The entire x-carriage is twisting under the weight of the CNC4Newbie slider. I have an original 2015 (i.e. the 2 maker slides) with the 1/4" bolt stiffening mod. I shimmed the plate out at the bottom to make it less pronounced (the photo below is after shimming) so the actual spindle is not terrible, but you can only shim so far before it gets stupid. Is this only fixable via switching to the newer thick x-axis extrusion? Since changing the x-axis extrusion apparently involves also swapping out the drag chain (not excited - since this machine has the solid drag chain)
please excuse all the dust, it was the maid’s day off…
