I’m not sure if this is an Easel Pro issue or my machine. Before being yelled at, I do all my work in Easel Pro and output a gcode file to my Boxzy. I’m only two paychecks away from getting the 1000mm Xcarve.
Ok, this issue is this, I create a 47.4 x 47.4 x 23mm square, outside cut chosen, within the square is a circle, 43mm x 3mm. I hit run and it cuts the design perfect. I then flip the workpiece over 180degrees on the X axis. I change the depth of the circle to 14.4mm I hit run and this is where the problem occurs. When the job is done the deeper circle is off center by about 3-4 mm on the X axis.
The only thing changing is the depth of the original circle pocket and flipping the work piece 180 degrees on the X axis.
The circle in the middle of the box is centered to material.
I hope someone can help me with this, I’m stumped to say the least.
Thank you,
Glenn
www.airshipmagic.com
