Hi guys I’m having a problem with my motors not locking after my rough cut it will not let me lock the motors in place is there something I have to do to get them to let me lock them? I have ruined two projects. Very frustrating any help would be appreciated. for got to mention I very new to cnc
Can you go to the Machine Inspector, send $$, and check the value of $1?
It should be $1=255
I don’t no how to go to machine inspector
Machine—>Advanced–>Machine Inspector
or press CTRL+SHIFT+D (CMD+SHIFT+D on Mac)
If you have the XController there is also a dip switch where you can disable “reduced idle current”, this one should be switched to OFF so the steppers get full current when idle. That and making sure $1=255 as Neil stated should do the trick.
The value for $1 is how long a motor stay energized after a move, before it is turned off / get no current. The value represent time in milliseconds, so $1=10 or $1=50 mean 10 / 50ms. The value 255 = ON all the time which is what you want.
Thanks for the help I found what you guys are talking about all of my $1=255 but I still can not lock the motors.
Haldor you said something about a switch not sure what you mean? I do have an x-controller I got my about 6 months ago.
Are you showing the dip switches on, before you turned them off? They look in the ON posiion in your picture… just want t clarify,
Thanks,
Tim
That’s what he was showing. They are on in the picture.
What are the exact positions for the dipswitches to ensure that the motors will lock during a tool change and that everything else is correct?
I just turned all #4 to off.
Now I have:
S1:
#1-on
#2-off
#3-on
#4-off
S2:
#1-on
#2-off
#3-on
#4-off
S3:
#1-off
#2-on
#3-off
#4-off
Is this correct?
Yes.
And make sure $1 = 255
