I too would like access to this capability!
Please?
If possible can I be added to the list to try this out?
I think I might need this too
@MichaelGrigg @BrandonR_Parker @JGillier @TimPillsbury @JonUdell @KevinCanterbury @Syxxstring @AK_Eric @TimothyMuse @MichaelRRutz Happy New Year! You’re in!
@EricDobroveanu can I get in on this too? I’ve been accomplishing the same by just duplicating projects and scaling my shapes. This would be a lot easier… Thanks in advance!
@EricDobroveanu some place left to try the two stage cut ?
i was using the offsetter to try to do this operation =/
Please add me to the list.
Can you please add me to allow two stage cuts. Thank you. Jenny
i am about to set up my first two stage cut. Why is there only one Cut Settings Tab? Shouldn’t there be a Tab for each size bit? Using a 1/4" bit for the roughing stage should have different variables than with a 1/16" bit, Should it not?
Hey @MichaelGrigg,
Appreciate the feedback, we will definitely put it to use!
You are certainly right, roughing and detail should have different cut settings. Easel doesn’t do a “tool change operation” when you have a roughing/detail bit enabled. This is because in the walkthrough you have to choose which pass you are doing, and Easel will only cut the pass type that you selected. Then, when you are doing the next cut, you need to switch bits and select the correct bit in the walkthrough.
Right now the work around for this is to change the cut settings in between your roughing and detail pass.
Let me know if you have any more issues!
i also see a new area on the carve screen for motors locked and unlocked. Neither of these buttons seem to do anything when i push them. Whats up with this?
please add me to allow two stage cuts. Thanks
Thanks Eric but where do I find it or maybe I need to update something?
@TroyGrela Cut away!
@Kasba Refresh your browser, and you should see “+” sign next to the bit/cut settings:
