Would be cool to try this feature out! I´m in the stage of just playing around with the machine and software, and i like the direction Easel is going! Soon starting with my first real project using the X-carve!
Hi Mikael,
You have access!
i would like to have access please! thanks!
I may be the last person to realize this but, I just figured out that the two stage cut can be a real project saver. I just had a project cutting a vectorized image (using the new app) and when it completed I saw that some of the lines were not cut. I had not seen any red on the 3D image so I just assumed my 1/8 bit would be fine.
It was an easy task to just go back into easel and select two stage cut with the detail using a 1/16 bit. Then I just had Easel run the detail portion of the job and it went back and cut all the lines it missed.
So even if you do not start out planning a two stage cut it is easy to just add a detail cut to clean up anything that might have been missed.
I would like to have access to try this out please.
Just gave it to you @OskarThorBjornsson please refresh easel and it should be there. If not log out and log back in and it will be for sure.
I would like access to this feature, please!
Access to this and the vectorizing feature would be appreciated!!
I’d love to try these new features out too. Just got my Fully Loaded X-Carve set up and loving it!
Great - thanks!
We are beta testing the new App Store. Click the smiley face.
What smiley face?
It’s at the top of the screen in Easel.
I hate to ask, but can I also get access to this feature? Please.
I would love access to this feature.
I plan on doing a 2 stage piece that will be using a 3/8" core router bit to make a nice cove-edged inset, and then a 1/16" detail bit to cut out holes in the inset part. Essentially what I’m making is a vent return cover.
I could do it with Easel as it is currently, making 2 separate projects, but I’d rather be able to specify which paths get which tool.
