Hi all,
I have just upgraded my X-Carve to screw drive, the machine seems to be setup well, certainly works fine in Easel. However when I try to use UGS it seems as if it is firing off each step and micro-pausing rather than running a continuous stream of commands. For the life of me I cannot work out why the same machine running the same FW behaves on Easel but not at all on UGS???
Jogging in UGS (failing to do a 10mm jog)
Jogging in Easel (10mm jogs)
Firmware Version: Grbl 1.0c
Easel Driver Version: 0.3.20
UGS Platform v2.0 (build 20200425)
All pots running at 180degs from zero
XY Pots are Off, Off, On, Off
Z Pot is Off, On, Off, On
GRBL Settings
$132=154.000 (z max travel, mm)
$131=800.000 (y max travel, mm)
$130=800.000 (x max travel, mm)
$112=100.000 (z max rate, mm/min)
$111=4000.000 (y max rate, mm/min)
$110=4000.000 (x max rate, mm/min)
$102=50.059 (z, step/mm)
$101=25.000 (y, step/mm)
$100=25.000 (x, step/mm)
$31=0. (rpm min)
$30=1. (rpm max)
$22=0 (homing cycle, bool)
$21=0 (hard limits, bool)
$20=0 (soft limits, bool)
$13=0 (report inches, bool)
$12=0.002 (arc tolerance, mm)
$10=115 (status report mask:01110011)
$6=0 (probe pin invert, bool)
$3=4 (dir port invert mask:00000100)
$0=10 (step pulse, usec)
