I’m using ugs version 1.0.9. In the jog control I can change the movement from mm to inches however in the machine status it will only read in mm. How can I get this to read in inches?
Change the parameter in grbl $13=1 to report in inches. The default is $13=0.
Can I do that through ugs with $$?
In UGS at the command entry spot just enter:
$13=1
and hit enter
Perfect! Thanks alot.
