UGS Platform visualizer
Hello All,
I have my Pi running with UGS Platform. It works fine although I had trouble configuring the X-Pendant with my azerty keyboard.
That being said, when I use UGS nothing appears in the Visualizer window. All I have is a grey window. This is just scary because I can’t even check if I loaded the right gcode. I use Aspire to generate them. Any hint?
Thank you.
Product Version: Universal Gcode Platform 201609300101
Java: 1.8.0_65; Java HotSpot™ Client VM 25.65-b01
Runtime: Java™ SE Runtime Environment 1.8.0_65-b17
System: Linux version 4.14.34-v7+ running on arm; UTF-8; en_US (ugsplatform)
Grbl 1.1f
Visualizer doesn’t work on the Pi.
Just a known limitation.
Thank you @JustinBusby
I was hoping it was because of a wrong postscript. I hope this will be fixed later. I have to be very careful on which file I load.
Btw, what postscript do you use for the Xcarve? There’s Grill (.gcode) or G Code (.tap)
For Vectric?
I have a custom PP that I modified from one of the Xcarve ones.
Yes I am using Aspire. Why a modified PP?
