Great idea - it works for me.
Peter
Peter
Hi @New_Brit_Workshop and @DanBrown,
Yes, I am concerned about the weight of the hose as well; both in terms of both the weight on the X-axis makerslides, as well as the torque on them resulting from the hose being supported far away from the makerslides. Iād like to go with at least one 2-1/2" dust collector hose, but I have some ShopVac hose laying around that is around 1-7/8" to 2" diameter and I am thinking of using two of those, one on each side of the router, tucked in as close as possible to the X-axis makerslide to minimize the torque.
Iāve seen the KentCNC design, where the hose is located in front of the router, but I like Peterās design better, where the hose is closer to the X-axis. Another design I considered was simply screwing the dust shoe into the bottom of the Z-axis makerslide (the self-tapping screws), but then you lose Z-axis clearance, and have a completely non-adjustable solution.
My main run of ductwork goes directly above the X-carve, diagonally, but right now the nearest drop is off to the side, almost at table height. Iām planning on reworking the ductwork so the drop is about three feet above the wasteboard, roughly in the center, and having the minimal length of hose to cover the entire area. Iām also hoping that the suction will help counteract the weight of the hose when the dust collector is on. But Danās bungee idea may also be needed to take up the slack.
I am going to have to experiment here. My X-controller is coming soon so this will be part of several upgrades that I am going to do at once.
Thanks for all the ideas!
Much Appreciated.
Hi Everyone
I have now added a .dxf version of the drawing file at the top as some people have older versions of CAD software. I saved it in AutoCAD R14 compatible dxf format which dates back about 20 years.
Peter
I assume folks have seen The new Brit Workshopās new design (itās a change, he posted it this week) directly on the gantry while preserving z-axis movement?
You can see it here
Yes, this thread is about the very latest design.
Peter
Hi Everyone
I am just finishing the editing of a 3 part video series which describes the design process for the Ultimate Dust Boot using VCarve Pro. I am hoping that it will provide a useful tutorial of the software as well as showing my design approach for this particular project.
I will post the links when the work is done - probably within the next 48 hours.
Peter
I have now uploaded the three videos that describe the design process for the Ultimate Dust Boot using VCarve Pro. I have tried to make them useful not only to people making the Ultimate Dust Boot but also for anyone looking at the design process with VCarve Pro. Here are the links:
Part 1:
Part 2:
Part 3:
Cheers,
Peter
We just cut G10 plates with our X-Carve and donāt work with wood. Do you sell this as a kit?
Hi Chuck,
No I do not sell these but you are free to take a copy of any of the files and give them to someone else to make for you.
Alternatively, perhaps one of the 50 plus people in the US that have the plans already might volunteer to make one for you for a small fee.
Everything I do is free of charge - but those people who want to support my work are invited to buy my e-book from Amazon
Peter
Thanks for the reply Peter.
You do great work, I enjoyed your videoās. Which e-book would you like?
From the OP:
āIf anyone wants to help me in return then all I ask is that you consider buying a copy of my ebook āStone Messageā from Amazon, It is a mystery thriller and only 99 pence in the UK. Many thanks.ā
He has a book on Amazon heās selling.
Sorry, its early in the morning here.
Hi Peter if I could get a copy of the plans that would be appreciated.
darren.willsmore@endeavour.sa.edu.au.
Ceers
Darren
Hi Darren
The plans are on the way. Do let me know if you need any advice. How about posting a picture of the finished dust boot?
Good luck.
Peter
Hi Robert,
Peter
Hi Peter, I would like to have a copy of your dust boot. My email is rparris31@comcast.net. By the way, you make the best you tube videos! I truly enjoy them.
Hi Roger,
Peter
Does anyone know where I an source the bristles?
