Unable to "add bit" to tools (Solid Carbide Ball End Mill)
I have the above mentioned bit, but when I try to “add bit” it’s nowhere to be found in the list of bits that can be added. How do I add it?
Where it says other in the bit selection just type in what you have.
I considered that, but it’s an inventables bit so it seems like it should be listed with their other bits. Thanks.
Easel does not support ball bits natively.
IF doing pockets, you will need to adjust the stepover amount in order to account for the scallops that a ball bit will create…
The stepover can be adjusted by going to machine>General Settings you will notice that there is a stepover default of 40% (for endmills) and a v-bit stepover default of 1% (for vbits).
More info on scallops and stepover: How To Choose a Stepover for 3D Profiling - CNCCookbook: Be A Better CNC'er
Thanks SethCNC!!
