I searched the forum for “unattended” and found quite a few admonitions never to do it. Okay. I started this project and the current toolpath has been running over two hours and has 51 minutes go go. Other toolpaths took more than an hour each. Supper came and went while it was running. I’ve had to go to the bathroom three times (there’s not one in my shop). What are you guys doing in this situation, hitting “Pause”?
How about any of you who do leave it unattended. How do you justify doing this? What safety precautions do you take?
My shop has a security camera in it. It doesn’t show a close-up of the CNC, but I can see it well enough to tell if there’s trouble. It’s tempting to go in my office and work in a quiet and dust-free environment, keeping an eye on the security monitor. But I tried doing that, and it cranked up a pretty heavy guilt trip.
i keep a smoke detector over mine and a webcam so i can view on my phone if too far away to listen but there have been many occasions i have been in the shop for the duration of a 18 hour carve
I’m sitting in the living room watching TV while it is carving away right now. I got the camera for the Raspberry Pi which I can watch through cncjs. And cncjs lets me watch the progress of the carve through the model. The only thing I don’t have hooked up yet is the dust collector powering on and off when the carve starts and stops.
So far the PI was the best “upgrade” I’ve done yet.
I use this camera. Was super cheap so don’t care about it getting dirty in the shop. Then if I need to come into the house, I can pull up the app on my phone and keep an ear on it, and check the screen if I need to. Works great!
Care to elaborate on your cncjs setup? Does the Pi connect to the arduino over serial or is it running independently with just the camera and a network connection?
I am in ear shot, working with other tools, outside, or in the house and come out time to time to check on it. At this point i trust it enough to leave it unattended while I’m home. I have this past week, took a nap since it had 2 hours left and it was 1am. Set my alarm and checked on it after an hour, then right before it finished.
In the beginning I would never do that, but now that the kinks are worked out I have no issue leaving a known program running. New code on the other hand, I stay in the shop.
OOH! I have been guilty of setting up an 8 hour carve, starting the machine, watching it for 10-15 min to make sure it’s behaving itself and going into the house and going to bed. When I come back in the morning, the machine is just sitting there quietly at idle and all is well. Just for the record and I am not sure if it makes much difference I dont run the 611, I have a 300W quiet cut spindle.
I have only done this twice out of necessity, needing to get a job done and having to earn a real living to pay the bills and support the hobby. I do more often let the machine run and not be directly in attendance though, I just make a point of routinely checking on it and listening to it. If something is gonna go south, it’s going to ruin the piece before I can react any way. Beyond that, usually the worst that will happen is a broken bit.
This is interesting. So what is the worst that can possibly happen if you leave it to do it’s job? Have there been cases where it’s cutting as it should and then freaks out and does something unexpected - especially if it’s a cut using a file you’ve used before?
Hey Darryl,
Happy to.
I got the PI combo kit for my birthday and added the camera later.
The PI is connected to the arduino via usb and connected to my network via WiFi.
On the PI I’m running cncjs ( webpage ) and have the pendant module installed as well. The pendant lets me hit it with anything that can hit a webpage ( ipad, iphone, etc ) and jog, pause, etc.
I have mjpg-streamer running on the PI which lets cncjs see the camera.
I create the gcode, upload it to cncjs on my laptop, set the spindle ( In person in the garage ), and hit play.
I also have the PS3 pendant pieces installed so I can jog with a PS3 bluetooth controller but I haven’t used it much yet.
I do have serial-port-json-server installed on the PI so I could use Chilipeppr or UGS to run the jobs over wifi but I haven’t used it.
So far I’ve had zero issues with cncjs. I love all the features in it and I think it will do a lot more than I use ( new to doing CNC work ). It’s never failed a job or crashed. Since it’s directly connected to the controller over usb I don’t have to work about the network dropping out or latency.
I have been running a Raspberry Pi 3 to control my X-Carve for a while now and would like to let those interested know that you can also run Easel Local from the Raspberry letting you use Easel as a sender and a CAD program, I have also used UGCS and UGCS platform without problems on the Pi. I have also used Bcnc and Chillipeppr. I like to use Easel for simple designs (designed on main system with Linux then sent from Pi) and UGCS when using the laser or any other code not created with Easel. Best system set-up I have had with this X-Carve.
I’m trying to set up the Raspberry Pi on my machine but am having a problem homing the x and y axis. The z homes with no problem. Any words of wisdom? Also, what amperage did you set for the stepper motors?
Many of my runs are 8+ hours long. I have a camera set up to watch remotely and wifi receptacles I can turn off remotely if something goes wrong. I am cutting only foam though, not wood, so if it stalls out it just melts the foam onto the bit and smells up the place. It would have to drive into the waste board with the collet nut before it would be a fire danger. If you are going to leave it unattended I would suggest the camera and remotely controlled electrical power so you can shut it down if it goes wild on you.
