how do i uncombine items on my project after i have combined them
You can’t. Would be nice tho
All you can do is un-combine if you haven’t logged out of your project. BUT it will go backwards through every change you have made prior to this and will un combine until you get to the element you want to change. Or you can use the xploder app.
I typically try and build in pieces on separate worksheets as I go along so the elements are broken up and If I need to make changes its easier. Then put the whole thing together at the end.
This.
However text objects wont uncomine (Xploded) into new editable text objects.
