Hi All. New to x-carve. I’ve been able to create projects but have noticed my finished work comes out higher on the right side. Design is straight, but finished work is not. We’ve tried resetting the work board, making sure everything is right- no luck. Any suggestions?
Thanks
I suspect your waste board is not on the same plane as the carriage travel.
Higher as in offset to the right/away from you or higher in elevation (Z)?
Skim your wasteboard.
