upgraded x axis risers no 2 inches taller bit cuts so far down then stops z axis needs to travel farther down. would there be a g code I need to change?
If you have the stock Z axis you may not be able to reach the original waste board.
You need to be careful i believe with the stock z axes the wheels have a chance of coming out the bottom. Best thing you can do is add a block under your work if needed.
I’m glad you guys were able to decipher that…
Assuming you need to have the full 5 crawls of movement, you will require longer creator slide and a custom lead screw for the z-pivot. In the event that you will do the ACME update, I can assist you with a custom arrangement.
