Upcut machining
The program sends the cutter “with” the feed and not “against” the feed as in the feed directions on a hand held router. The cut is small and also the tool but it goes against my training as a universal miller (eng),
Can that feed direction be specified ?
according to this no…but I don’t use Easel, so that could have changed. As the responses said, you can use other software to do it. Turning Off Climb Milling - Easel - Inventables Community Forum
