HI
I need some information on upgrading my 500mm x-carve to 750 by 500mm. It looks pretty easy as I think I can buy a 750 makerslide and use the exist frame parts that came for the X-controller board. I think I can move the controller and get a longer belt then install the wider maker slide. I going up only a bit because this is in my classroom and i dont have room. Also I think it should be a cheap way to get more versatility.
So basically has anyone done a similar upgrade that can offer some advice? I think I can make the wiring work since Im only going a bit wider.
Any help is appreciated.
