What dust control system is that? I like the longer brushes
It is the Suckit dust boot.
However it comes with only 1" long brush and I wanted a little more clamp clearance.
So I ordered an 1 1/2 brush from McMaster Carr and cut it down to 1 1/4.
It works great.
Did you have to modify the dust boot for additional width?
Yes I did.
I took Jeremy Johnstoneās Idea and ran with it.
I still want to see what suckit comes out with though.
Did you route it out so the entire body of the router could go through the base plate? Or is that standard
No, it comes that way.
But it also comes with a shield that screws on from the bottom with a hole just large enough for the bit.
With the down draft from the router itself and the suction from the dust collector it is not needed, so I leave it off.
Here are the simple modifications:
I highly recommend to do what @JanVanderlinden did; two notches in the aluminum rails for the two bolts instead of one.
@JanVanderlinden I am glad you are enjoying it and I must thank you for being patient. This is the first production run of a new product, and my first time bringing a structural / mechanical product into production (not including circuit boards etc.) so it has been an interesting learning experience. Itās one thing to design and build a one-off item for yourself but making a quantity of them presents a lot of unique challenges!
I should finally be getting a test unit to the Suckit team in the next couple of days and hopefully I will be getting one of their test units to perform my own validation with. I wanted to make sure the users who had issues were able to resolve them and I think that is moving along well now.
Ok finally installed my zplunge with 30mm drop plate⦠113mm of travel, rock solid. I also installed my 292oz motor and 2:1 pully.
Now to figure out the suckit.
This looks like 1:2 gearing. Compared to 1:1
- if you keep the same ustepping, you gain double speed, but lose half resolution
- if you halve your ustepping, you keep the same speed, same resolution, but with less torque
Did you mean to do the opposite (i.e. 40:20) ? Compared to 1:1
- if you keep the same ustepping, you lose half speed, but gain double resolution
- if you double your ustepping, you keep the same speed, same resolution, with more torque
@EliasPolitis, I think youāre right about the gear ratio, but to be clear on the semantics with your following examples - when you say āhalve your usteppingā I presume you mean with the microstepping value considered as a ratio (i.e. 1/2 steps gets halved to 1/4 steps). Some people would think of 1/4 steps as more microstepping (more microsteps per full step) than 1/2, so just wanted to be clear. (For instance, the DRV8825 datasheet has the verbiage āā¦full-step up to 1/32-step modesā¦ā)
In any case, doubling the motor pulley on the Z is a change many people make with the intent of speeding up the Z axis, since it is pretty slow relative to X/Y, so it can slow things down a lot when doing a carving job with a lot of retracts. By virtue of the screw drive, the Z axis has much higher resolution than X and Y already, so cutting that in half can be a reasonable trade. The bigger motor is there to make up for the halving of mechanical advantage due to the new taller gear ratio.
Yes. Itās kind of like talking about aperture in photography (smaller aperture - higher f number and vice versa).
Anyway, I just wanted to point out that by changing the gear ratio from 1:1, one way you favor resolution, the other way you favor speed.
40:20 twice the speed, I doubled the motor so same torque. With a 4 1/2" Z I need the speed.
I used a 40 tooth 1/4" pully and 180mm belt.
Hi are they for sale yet
ahem⦠thatās a valid TLD
I was finally able to get the z-plunge installed, and also received the wide rail suckit upgrade kit installed. This rail is a major improvement over stock, and while there were some hiccups early on, everything Kyle sent to correct the issues have worked flawlessly so far. I should mention that there is not an additional extended plate that mounts to the existing spindle mount plate. It is a replacement spindle mount plate with the extension, which is the right design direction in my opinion. I had the old z removed and new one carving in about an hour. Itās a very straight forward install, and truly a drop in replacement.
The suckit upgrade kit was also a breeze to install and came with everything except the aluminum rail sections, the shoe, and brush. The kit included 3d printed āy axisā extensions to account for the additional thickness, and 3d printed āx axisā extensions to mount to an existing acrylic shoe as opposed to all acrylic parts. I donāt see any reason why the 3d printed parts will be any less effective, but thought it was worth mentioning. The suckit is a proven design already, and this kit is no different. It works great, and if I were in the market for another shoe, it would my go to.
Suck it upgrade kit? Where did you get this?
Does it come whit the threaded rod ?
@ScottBongiorno The Zplunge kit can utilize the acme rod included with the original X-Carve kit. I do have some custom longer acme rods which I can make available if necessary.
@KyleKronyak So at this point has the drop plate been integrated into the design on the new model? What is the lead time if i were to order one today?
