Want to make sure that I’m not missing anything here for upgrading my 500mm Shapeoko2 to a 1000mm X-Carve.
- Upgrade kit
- 1000mm rail kit
- 1000mm wiring kit
- 1000mm wasteboard
- 1000mm drag chain (already have it)
Thanks!
Thanks!
Because I always overdo things, I would also order some extra:
Extrusion Brackets
Extrusion Bracket (Gusset) – Inventables, Inc.
Pre-Assembly T-Slot Nuts -
https://www.inventables.com/technologies/pre-assembly-t-slot-nuts
I put two supports equally spaced in the wasteboard support frame, to better support my wasteboard (an extruded aluminum bed in my case) Having extra extrusion brackets was necessary. I have them on each side of each support section. My frame is rock-solid
Any you will never have enough t-slot nuts. Just get extras
Hello,
I currently have the Shapeoko 2 as well and I’m looking to upgrade to the 1000mm x-carve like you. You mentioned you’re getting the upgrade kit but I was wondering if you were going with the x-carve core components ($292) or the shapeoko 2 upgrade kit ($200)? Can you explain what the difference is? I’m not quite sure. Do you plan on keeping your same power supply? Thanks
Pat
