Upgrading X motor from NEMA 17 to 23
In order to take full advantage of the Dewalt 611 router I have discovered that I really need to replace the X motor. If I am cutting at the speed and depth the 611 allows I will occasionally see a missed step on the X axis.
So I ordered a new NEMA 23 motor (from Amazon because Inventables was out of stock) and 1/4 inch pulley from Inventables. The motor arrived yesterday and the pulley should be here tomorrow,
My question to the forum is: has anyone changed out the X motor on an assembled X-Carve? Putting the new motor on should be a piece of cake since the mounting holes for the 23 are tapped and do not require a nut on the other side. But it looks like getting the old 17 off may require taking apart the spindle mount and Z axis so I can reach the access holes to loosen the nuts on the 17.
Of course I would like to not take apart anymore than necessary so if anyone else has done this and has any advice I would appreciate hearing it.
Get a set of ignition wrenches and you can reach the nus without taking any thing apart. Ace hardware carries them.
Dave
That would make me very happy. What is special about ignition wrenches? I am not familiar with them.
They are small only 2 to 3 inches long and thin. come in inch and metric. do a search and you will see what they look like.
Dave
Perfect, thanks for the tip.
Another thing special about them is when you could actually use them. I remember setting the points and dwell in the good ole days. I think it was around 74 when Chrysler came out with the electronic ignition.
