I’ve got an ASUS Chromebook to run my CNC in my shop. I set up/calibrated my X-Carve using my Mac Mini (brought it in the shop from my office in the house) and it ran fine. I was under the impression once I did that intitial run I could use a Chromebook to run the carves in the shop.
I rather have a $200 Chromebook in the shop then using a actual MAC/PC if possible. Is this not the case? I tried to install the drivers but i get the error message they cannot install due to it being a CHROMEOS.
Any advice? Before i bought my X-Carve I saw quite a few people using the Chromebooks to run Easel & the X-Carve so that’s why I purchased a Chromebook.
I couldn’t get mine to work on the Chromebook default OS, but installing Linux Mint was pretty easy (never done it before so newbie there). Once that OS is installed, you can install firefox/IE/chrome, the easel driver, and its pretty much smooth sailing from there.
Did you do anything special to get the driver to work on Linux? I have a Chromebook and I’ve installed Linux but the driver won’t work for me. The carve button stays blue and I can’t seem to get it to turn green. Any tips?
Did you install Linux Mint or another variant? It’s been a year since I fiddled with it so I don’t know if any updates/changes took place that would cause problems but I don’t remember anything specific that I had to do. I just ran through the Mint install > installed firefox > installed plugin
I installed Linux Ubuntu 18.04.4. Do you know which version of the Easel driver you have installed? I downloaded 0.3.18 but maybe if I downgrade the driver it could work, or maybe it would be best to delete Linux Ubuntu and start all over with Linux Mint. The only reason I went with 18.04.4 was because that was what Inventables supported (just not when it’s on a Chromebook). Thanks for your response!
I know this is a very old post but I just recently got into CNC thanks to a surprise Christmas gift of a Genmitsu 3018 pro. My only available control computer for it is an old Acer c720 chromebook. I’ve got that up and running with crouton and Ubuntu 18.04. I was able to get UGS and Candle working with some effort but Easel stubbornly refused to connect.
Here is what I finally did to get it working, in case someone else runs across this post:
For me, with Easel open in Firefox this instantly changed the carve and jog buttons from blue to green and I was able to now control my machine from Easel for the first time. You may need to log out and back in to Linux if it doesn’t but that is what got it working for me! Hope this helps someone out there as I have spent weeks trying to get this working - Glen
