Using MeshCam with X-Carve
Anyone using MeshCam? We designed a piece and imported the g-code into Easel. We are trying to slow down the travel speed and can’t seem to locate the G-code line that responds.
Wildwood School
If you are using the latest version of GRBL there should be an option just left of the progress bar that lets you adjust feed speed + or -
In Meshcam, you need to edit the tool you selected This will allow you to change the speed.
There is a list of .tps files for importing into MeshCAM at: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
It’d be great if folks would share other settings.
