Hi There,
I’m fairly new to CNC milling and the Carvey machine and wanted to get some clarification - Am i able to use bits not sold by Inventables on the Carvey machine and if so, would kind of things should i be aware of? For example, does a third party end mill require the plastic coloured ring which i assume is for depth control to work on the carvey?
The only constraints i can see is paying attention to the shank diameter and making sure i have the right collet to match the shank dimension. Is that correct?
I ask this as i live in Australia and the shipping costs are quite expensive when ordering from the inventables shop
Thanks very much for the help!
