Using Vcarve In Easel
When saving multiple tool paths from Vcarve to cut with the Xcarve, Will easel recognize that there will be tool changes or do I have to save every tool path as an individual and then perform them as each one finishes?
Every path as an individual file and manually change.
In the end, it’s worth it in case you have to rerun just 1 path.
Awesome thank you
Page 174 of the attached file…Dropbox - VCarvePro.pdf - Simplify your life
then you import your saved toolpath to Easel…
YES, you can us UGS or PicSender or one of many others, but as stated several times above, it is as simple as saving the “tool-path” in the V carve software and importing the resulting Gcode into easel. You just have to have the correct post processor when you save the tool path.
http://easel.inventables.com/downloads
