Check out the easel project I have started
https://easel.inventables.com/projects/BQkuge_LgJzuxOQg-Olasw
What I am wanting to do is use a v bit on the shape I created but be able to adjust the depth like the text example in the project.
I use illustrator
You set carve depth in Easel for any object you have in there.
Click object of choice, select the Cut panel and slide (or enter numerically) to your desired depth.
Thanks, but what I meant was how to control the depth around the shape.
For instance; start at 1MM then go to 1.5MM then to @MM then back to 1MM . like how a vbit cuts for a text objcet
I’m a little confused what you’re trying to achieve, but…
If you manipulate the nodes you’ll get more control over the width (and V-Carve depth)
