wasn’t V-Bit supported in easel without pro? its been a while since i was last in easel and just started carving again. can anyone confirm this?
No, you’ve always needed pro to use a V bit correctly.
Now if you had an account before July 21 of 2020 you get 4 free days of Easel Pro a month.
Go to the Pro Carve button is the upper right hand corner then to the options tab and you can select Use A Free Day.
Good Luck,
Russell
thanks for response I do have 4 days free. I was just wondering if things changed. Thank You
Bought my xcarve back in 2016 and I do not think there was a Pro version at that time and I used a V-bit to do work back then. Just simple stuff though.
