Just wondering if these bits come to a true point or is there a flat section on them? Also has anyone tried V Carve Inlays with these bits?
https://www.inventables.com/technologies/bit-set-for-v-carving
I think he’s asking if anyone has purchased these.
This is what Phil usually suggests and what I use: Amazon.com
I bought the set from Inventables as part of a gift card I received and I’ve yet to actually use them.
I remember reading somewhere that they do in fact come to a point and not a flat but I can’t find the source of that.
I’d test carve but I’m in the airport on the way to a wedding. I’ll see if I can find that source.
I have both of those bits.
They work well but not as good as the one posted above from Whiteside.
I ordered one of these and received a bit with a 0.05 flat tip. I sent it back for a refund without any problems. It seems like there might be a wide variance in their quality control.
What is the flat tip length on that bit
Thanks Phil. Does this hold true for all their v-bits? I have several of their 60 and 90 degree bits.
I ended up getting the 1541 from a store on ebay, they didn’t have the 1540 in stock. I have not used it yet though.
It has essentially the exact same measurements as the 1540 but it is a 3 flute instead of just 2.
Would you anticipate any issues from using the 3F versus the 2F ? I would think the 3F should give a little smoother surfaces? Still a newbie with wood/CNC, so just guessing there based on the things I have read so far.
