Thanks for the tip!
I used that and it worked almost too well. Was a bit of a pain to get off because I cut through the “tabs” of the tape.
And it managed to point out a couple issues I had with my machine. I tested the X direction and thought it wasn’t completely lined up with the lines on the waste board so I made a large square and cut that into the waste board. Turned out it was straight. But in doing that I noticed one of my wheels was out of adjustment.
So, Thanks for the help!
I think I’m still going to look at the vacuum as it seems like it would be must faster and easier to line things up, but the tape/glue trick definitely works!!
Quick update. I scored a whole veneering setup with a large vacuum pump, valves, switches, etc. I ordered a cheap set of clamps off ebay so I can see how it goes.
Quick update. I finally got the parts to hook up the vacuum clamps I got from ebay.
Unfortunately I was really disappointed with how they work.
The holes for the screws leak unless you seal them because the holes are in the middle. I’m still working on fixing this because they are leaking enough air that 4 of the clamps together won’t hold.
One clamp held a board fairly well but I could still easily pull it apart.
