Vacuum + Spindle Mount
Anyone know where I could find a way to fit the FEIN Turbo I hose to the Spindle Mount, and if there is any way to make it automatically start with the machine?
Thanks in advance!
AD
Well if you have the X-Carve you can make an attachment for the hose pretty easy, and to autostart the vacuum you will need to hook up a solid state relay. I believe Inventables sells one and if you search the dewalt threads you will see a diagram for it with the dewalt hooked up to the relay, same thing as a vacuum.
