*vcarve pro 8.5 mishap*
my 1st time to do vcarve pro and was very frustrating.
does it matter if my material is a particle board?
this was the settings. should i lower the feed rate, z safe, plunge rate?
—what do you recommend?
are my settings fine?
If that is the particle board that has the film on it like they use in cheap shelving and desk and such it is a pain to work with as it is full of voids and seems to be of a lower grade than plain particle board from the lumber yard. I have done vcarve and 3d cutting on plain particle board and for the most part everything has came out fine but the other stuff was a no go. Don’t know your lumber prices for your area but here a 4x8 sheet of 3/4 mdf is just under $30 and goes a long way
:joy:
i just tried it on that particle board since that’s the same thing i used for end mill carving.
i know now that they’re not for v carving at all.
V-Carve MR J 665.gcode (282.0 KB)
were you able to open it?
i also finish another vcarve set-up. may you help me transfer it on easel with the gcodes for each carvings?
i have vcarve pro 8.5
this? i can’t i don’t know why.
i could not load the image.
i’ll appreciate that but i get this message when i download it.
where would that be? download folder
i already Downloaded the Easel post-processor for Vectric
