VCarve Pro into easel
I have VCarve pro and when I save the toolpaths into easel mode and import it into easel it is making the starting point in the lower left corner in easel and I guess the profile paths are set for center? Where do I change this to fix it?
I am a total newbie so sorry and thanks in advance lol.
Ted
Check the Material setup at the top of the toolpath side (right side). The XY datum should be lower left
Perfect! Thanks as always!
Im having the same issue with the importing of gcodes to Easel, I checked in Vcarve pro to make sure my datum was centered ( it was in vcarve) however in easel its lower left. Is easel lower left by default and Ill have to use lower left in Vcarve as well?
