Vertical Wobble in Z Axis
I am having issues with cut depth across the cutting area. At the end of a carve the bit ends up dragging across the work as it goes to home. I am wondering if the wobble / play as shown in this video could have something to do with it. Is there a way to remove this wobble? Thanks!!
z wobble cnc|video
The Eccentric Nuts are positioned such that the V Wheels are not as close to the rail as they should be…
Eccentric Nuts See what they are: Eccentric Spacer | Inventables
X Axis: X-Carve Instructions: Adjustable V-Wheels
Y Axis: X-Carve Instructions: Adjustable V-Wheels
Z Axis: X-Carve Instructions: Adjustable V-Wheels
Thank you Seth! It totally worked and I just spent the last 3 hours cleaning up my cnc. Appreciate you taking the time to instruct.
