Was Two Stage Carving Removed?
I saw a thread on here where you could do two stage cutting, one large bit to remove most material then a small bit to refine it. It was showing the it was under the advanced tab under the machine tab. Mine does not show this option. Was it removed or is it not available in the standard Easel package ?
Easel-2stage
Oh ok, I see what to do now. The last thing I saw was you had to select it through the advance feature on machine tab. Thank you for clearing that up.
