Waste board PDF in scale
Hi folks,
how can i print the waste board PDF in scale?
https://workbench.grabcad.com/workbench/projects/gcl5zpCuwqCXWLvYktLQBc-2IHvossNo37ycTOkzg6gREW#/space/gcvs_XeRNVzNkfG_tFTAMd0C2lBbCsLcagOxXb1Jlki0kT/link/144725
When i downlaod it and open in Acrobat Reader, i select print as poster ans 100% scale.
But is way to small.
Any hints how to easy print it in scale?
Thanks
that is because what you linked to is not the printable part but the specification page for the waste board.
if you want to print the silk screen part (the printed part) then it is located at https://workbench.grabcad.com/workbench/projects/gcl5zpCuwqCXWLvYktLQBc-2IHvossNo37ycTOkzg6gREW#/space/gcvs_XeRNVzNkfG_tFTAMd0C2lBbCsLcagOxXb1Jlki0kT/link/140717
or
https://workbench.grabcad.com/workbench/projects/gcl5zpCuwqCXWLvYktLQBc-2IHvossNo37ycTOkzg6gREW#/space/gcvs_XeRNVzNkfG_tFTAMd0C2lBbCsLcagOxXb1Jlki0kT/link/140718
depending on which size you need.
P.S. these are Adobe Illustrator files.
Hi,
i dont want the silk screen.
I want the pattern to drill the holes in an easy way.
Regards
sorry about the misunderstanding, but you said print.
if you want to “print the PDF” in scale then you would just need to print the PDF of the in scale 1mm = 1mm or 1 inch = 1 inch.
it list the dimensions on the PDF that you linked to.
I can not tell you how your printer handles that. I do not own your printer.
If you want to make a template then you have the dimensions, you would just need to make the template from what ever you have laying around and use it. you have the hole spacing listed in the PDF you linked (I would make at least two rows so I could align the bottom and drill the top after the first row).
good luck with whatever method you choose.
Replicator App in the App Library
