I’m confused…does the xcarve rail kit not come with the rails to mount the waste board. I was under the impression that the waste board was just that, the waste board and the threaded inserts and mounting hardware…not the rails that it attaches to
The rail kit has the rails and support extrusions that brace the waste board underneath. The Waste Board module only has the waste board, threaded inserts, and screws to hold it down. We did this in case you decide to make your own waste board then you will still have the support extrusions.
Thanks Zach…I was making sure the support rails came with it before I went and bought it from mcmaster…thanks
Hey zack…am I correct to cut my own waste board to 998x940mm outer dimensions?
Here is a direct link to the engineering drawing for the waste board. GrabCAD might make you login but the account is free.
Hi @MichaelSchafer I am so sorry. This was indeed confusing. I just edited that thread from March 3rd. Originally it was in the waste board kit but we changed it to the rail kit to support people that wanted to make their own.
I’d appreciate it if you deleted your post above so other people don’t get confused.
Does that make sense?
Original post deleted. So does this mean that the parts I ordered are extraneous? It’s OK, as I’m sure I’ll find a good use for them, and I’ve seen people saying that the extra support extrusions are a good idea…
I wouldn’t say they are extraneous but you get one in the rail kit. It is really a trade off of cost and precision. The more you spend on supports the more precise and flat the waste board will be over time. The MDF can settle over time creating variations across the board this is mitigated with extra supports.
It’s all good. My plan, once I get everything working 100%, is to extend the Y-axis out to 1500mm, so I’m sure it’ll all get used up along the way…
It comes with the 5 total extrusions. 4 are used on the perimeter and one for underneath the middle. You can add as many as you want.
3 of them are 20mm x 20mm x 958 mm
2 of them are 20mm x 20mm x 1000mm
This link seems to lead to a deleted file.
Nope, same thing. I’ve gotten to the waste board drawing before, not sure what is going on here today.
