Hi, have been able to figure most stuff out on the X-carve without much help. I keep having a constant problem with the z-probe and machine freezing. If it does make it through the complete job setup screen and generate tool paths, as soon as it goes to start a job it moves a fraction of an inch and just freezes. I can download the g-code and run the program on picsender after some fiddling with it. Still seem to keep getting some intermittent issues with the z probe. I can restart program and re-home machine and it seems to work eventually after a few tries. That turned somewhat into rambling but I find this pretty odd.
How old is the computer you’re using? I had similiar issues when I first started using an old computer with windows 7. I was told to try an external powered USB hub but just bought another computer and that solved the problem.
Russell
