We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youâve provided to them or that theyâve collected from your use of their services. Learn more.
okay yeah that seems like it should work and save you the cost of the tape and my apparent problem with tape flaring up I am curious how a v-bit like the one in the video will work because if you watch the outline of the sign get cut the tape flares up right away but not during the v carving
but back to the shellac once i apply that and then carve the engraving and then paint the engraving do you let the white paint dry in the carving or do you wipe the paint off the red before it has a chance to dry?
Or you can just apply a sealer like poly to the raw wood and the carve and spray the white letters then sand the surface and carefully paint it red. But that takes more skill in my opinion.
I just got burned on a project that I was working on and my methods because i didnt research them good enough so all i am trying to do is refrain from wasting a bunch of material like i did with my last desgin I basically wasted 40 wooden boxes
Get a scrap piece of wood and apply three coats of shellac, lightly sanding will fine sandpaper between coats. When the shellac is dry put some of the white paint on it and then immediately wipe it off. You will see how it works.
okay so this has gotten me to thinking if I wanted to go through all this color application process on a flat piece of mdf and then cut shapes out of it will the top surface be paintable with acrylic paint by hand you know desgins and stuff by a end user?
It seems like youâve gone down the chemical masking/finishing road. But, if you decide to revisit using a solid mask in the future, try contact paper. Itâs actually made of plastic or vinyl rather than paper, and if you have a very clean surface it sticks very well. The adhesive is much more tacky than masking tape because itâs made to hide things and not necessarily be removable, and itâs consistent. You also get the benefit of having a 24" width so you donât have to use strips of it and worry about the tape lifting along a seam line.
Dual-color signs are one of those things that everyone is clamoring to find an easy, cheap and consistent method for creating. Lots of people on here have different ways of making them using different masking and finishing techniques, as youâve seen already
yeah I think this whole thing would be easier to use a 2 or more color hdpe and create signs that way but that is alot more cost to the end user but so much easier from a manufacturing stand point
Alternatively, if youâre cutting pockets (not v-carving), you could carve the pockets as normal, then cut the same shapes as outlines in a piece of veneer, paint or stain the veneer, then glue it up.
yeah but I dont have a drag knife yet I would love to cut veneer like that but I am not able to yet unless you know if its possible with a regular router bit but i didnt think you could lol
