What bit do I suggest for acrylic?
Hello dear friends!
I wonder what bit to use to cut my toppers in 3mm thick acrylic? Examples in the photos.
Thank you!
to be 100% honest a laser is going to be the tool for that
that being said you want to look for single o-flute tools with a mirror finish
https://www.toolstoday.com/p-6453-cnc-solid-carbide-spektra-extreme-tool-life-coated-spiral-o-flute-plastic-cutting-up-cut-and-down-cut-router-bits.aspx
I’ve used 1/8" single flute straights before. Took me awhile to learn to run it fast enough to cut chips and not make swarf.
I have a single speed router @ 10k rpm, so I had to run my jobs at 60+ ipm. Make a few test pieces to play with your settings.
@WorkinWoods Thanks for your honesty. I had no idea that just with the laser the finishing was so perfect. For now I will continue to cut toppers in birch plywood.
Sorry about my English.
Greetings and a good weekend.
@DamnitJim When I bought my X-carve came along (Solid Carbide 2 Flute Straight End Mill) I’ll have to try it and see the end result.
Thanks and great weekend.
Best Regards from Portugal
