hi im looking to build a work station for me new x carve and wanting to know the size of the footprint with the side bourd kit attached soi can get it built before i recieve it
I was told 10 inches.
The reply 10in that is how much wider then the X-Carve is with the side board. So if you take the X-carve at 39in plus 10in Side Board comes to 49in wide (looking at it from the front left to right I call wide). and it’s 40in deep (rounded up a hair) This is footprint not the overall size.
1000mm Waste board https://workbench.grabcad.com/workbench/projects/gcl5zpCuwqCXWLvYktLQBc-2IHvossNo37ycTOkzg6gREW#/space/gcvs_XeRNVzNkfG_tFTAMd0C2lBbCsLcagOxXb1Jlki0kT/link/144725
1000mmsideboard.pdf https://www.inventables.com/technologies/x-carve-side-board-kit#file-attachment-disclaimer
Does anyone know the overall footprint/dimensions of the new version of 1000mm X-Carve w/ the Side Board attached? I noticed that it sits slightly off the main waste board and not flush to it, so it’s hard to make an accurate guess at actual footprint referencing the links above in @DougHill post. Thanks.
