Any input will be very much appreciated.
I get most of my end mill at Enco.
Try Drillman1 on Ebay, or you can search this forum there is a section about bits people using.
I echo the other Alan – I’ve bought twice from Drillman1 and have been quite happy with the results.
Thanks Brian, I couldn’t find link to give him. I forgot it was your link.
I send request to Drillman1 for stocking 1/4" shank bits, V-Bits and different sizes Ball headed bits. Let see if they start selling. I told them about your post and good feed backs.
Any suggestions for bits in Canada?
I had to start buying 6mm shank bits, for some reason there is a larger selection of them than 1/4 inch.
6 mm is 15/64 I think. How do you use it. Is it fitting 1/4" colette.?
The 6mm is .236 inches so about .014 smaller than the 1/4 inch. That is enough of a difference that the 6mm collet is required, But the prices of the 6mm bit is so much less it pays for the cost of the collet.
Ditto for my small bits. I’ve been buying router bits from MLCS for many years and have been getting v-bits for my SO2 from them.
I have a bunch of 6mm bits that I use in my 1/4 colett and put a small piece of electrical tape around the bit and the collet will tighten around it. It has worked well over 100 cuts while running the 611 at full speeds. I was kind of iffy about it at first.
Just bought a really cheap 6mm spoil board cutter.
MLCS sells good bits at reasonable prices. That’s the reason I buy from them. Compare prices before you comment.
I did compare, we’re talking about $3 bits for hobby use. I’m blind, if you please find 1/8 Shank .125 Down cut two flute spiral bit on that side sells for $3.
I’ve used drillman1, who has some real cheap endmills that are good as a default choice, and I don’t worry too much about breaking them. He also has the Viper endmills for aluminium. Those are expensive but very good. I have one that has been through a lot of mistakes on my part and hasn’t broken or dulled yet.
Also I have had good luck with onlinecarbide.com for odd bits like chamfer mills for aluminium or thread mills.
I just tried these guys (http://stores.ebay.com/carbide-shop) to get some 8mm endmills for aluminium.
Finally McMaster Carr is great when I need something right away.
If you read my post, I said I get my small bits from drillman1 on ebay; i.e., 1/8" and smaller. I don’t recall seeing anything that size on MLCS, but they do have 1/4" v-bits that work fine for v-carving.
!!! Sorry man you were the one who recommend Drillman earlier. I take my Comment, just leave Smiley face there.
