which router is best the dewalt 611 or the makita. need to replace my dewalt dw611
It depends.
There are pros and cons to both and unless your uses make one of these pros/cons into a deal breaker than it is a complete toss-up.
List is not ALL of them, just the main ones that come to mind.
Makita Pros:
Slower Min RPM
Easier to Change Brushes
Cons:
No LED light at the bottom
The Collet doesn’t snap into the Nut causing it to occasionally want to stick up in the shaft.
So you can change colletes on the dewalt i did not know that thank you for that info.
