What software can i use with a usb port ,or do i need a serial port
Ive tried mach3 but cant figure out how to set up connection
Ive tried pycam on linux but cant figure out how to start the xcarve after loading the project
windows or linux
tried easel but cant upload svg file without error
my xcarve is ready but im lost
Mach3 needs a breakout box or parallel port on the computer
what software can i use with a usb
Im no electrician ,I can build a PC but know nothing about breakout boxes
You will need a program to send the gocde file to the X-Carve if you are not using Easel.
I suggest you start off using Easel since it will allow you to design and send your project to the X-Carve with very little learning curve needed.
Just load up Easel in your Laptops browser and plug the usb into the laptop.
Ebr
January 15, 2016, 11:18pm
#6
I run my X-Carve with a windows laptop.
My tool chains are these:
Inkscape -> save as “optimized svg” -> Easel -> X-Carve
Fusion360 -> PostProcess -> Universal GCode Sender -> X-Carve
This works also:
Fusion360 -> export DXF from sketch-> Inkscape -> save as “optimized svg” -> Easel
I am running windows 10 on a note book work with v-carve and easel
$69 Windows 8.1 tablet - USB. I’ve had no problems importing into Easel.
I simply cant connect to easel anymore ,
how about a simple how to on connecting xcarve to vcarve
I wont live long enough to learn how to use 6 different software programs just to cut out one project
I use VCarve to UGS to my SO2/XCarve. Simple!!!
UGS SO2 ???
I build computers but I don’t know these terms
I feel like I did when I got my first computer back in 1994
UGS = Universal Gcode Sender https://github.com/winder/Universal-G-Code-Sender
S02 = Shapeoko 2 (predecessor to the X-Carve)
MRoss
January 16, 2016, 1:08am
#14
Universal gcode sender(Free) to his Arduino/GShield which is connected to his Xcarve. Why complicate things with Mach3
VCarve is Vectric software YOU referenced.
UGS is Universal Gcode Sender which has been mentioned thousands of times.
XCarve is the CNC you apparently have. Shapeoko2 is its daddy that operates the same way.
thanks
Ive used gcode sender but it does nothing
I cant even use easel anymore ,wont connect
I guess if I cant even connect to easel ,its pointless to try anything else ,
Its an expensive paperweight now
I’ve used UGS for the past year since getting my CNC set up and have never had a problem with it connecting. There is a difference between using Grbl versions. What version are you using now?
MRoss
January 16, 2016, 1:18am
#19
Easel has nothing to do with UGS. Do you have the driver for Easel installed? These are 2 different programs to talk to the Arduino
yes i do ,it was working ,now i only have one blue light on the board ,i did have 3 green but they are out now,is my arduino bad?
